and which path ?
What kind of sync location do you use?
what I said: local storage + WebDAV
Is it the local or WebDAV one? Or do they use the same name?
they use the same samba share
But the name is not identical?
of course - it´s the same share and DT3 assign the name automatically (name of the dms file)
The name of sync stores (that’s the one that isn’t visible on the screenshot) is actually chosen by the user. A screenshot of Preferences > Sync would help but only if it’s readable.
