I kept the profile settings from DT2 and modified the App Path to DT3. After this didn’t work, I deleted the profile and created from scratch again, following your Guide
What output path is in the Speichern tab?
Do you still have DEVONthink 2.x installed?
Yes, DT2 is still installed
I suggest deleting the DEVONthink 2 application - just the application - and seeing if the behavior persists.
deleted DT2 but behavior still the same
Hold the Option key and choose Help > Report bug to start a support ticket.
should I add a reference like issue#?
Just a reference to this forum discussion.
