After several tests and macro configurations following this thread, the “Document Display > Side-by-Side” function seems to have stopped working when a Markdown document is displayed in a document pane (i.e. next to a document list). It does work if the same document is opened in a separate window. I’ve tried restarting DT3 but it didn’t help.
Steps to create:
Data > New > Markdown Text
Enter any text into the new document
Click the icons for Preview, Source and Side-by-Side (or select them in the View menu).
Only Preview & Source work. Selecting Side-by-Side has no effect.
I have just confirmed this again with a freshly-created database.
I’m having the same problem. The list on the LHS is fine but there is no preview of the document. This is after the update to beta 2, before it was fine.
Thanks @BLUEFROG.
The View > Document Display options are all greyed out so I have to use the buttons above the Navigate bar
When I first click on the document title on the LHS, I get a literally 1 sec preview then it disappears. Each time I click around, I get the same 1 sec preview then blank.
If I display it as columns, the middle column gives me a small preview but the RHS is still blank.
/Applications/QuickTime Player > New Screen Recording has the ability to record your screen.
Press the red Record button, marquee the area to capture, then press Start Recording. When you’re done, you can stop the recording by clicking the menubar icon
Close the window to be prompted to save the file, or press the Delete button to trash the recording and start again.
One tip: Practice the behavior beforehand and capture the minimum area necessary to show the behavior. Especially on the displays with high pixel-density we have nowadays, recorded video can get large quickly.
In macOS 10.14, pressing Shift-Command-5 also allows you to record screencasts. I had forgotten this until just now since I spend time on previous OSes too.
If at all possible, we strongly suggest you move to 10.13 minimum instead. High Sierra is basically bug-fixed Sierra, with the same hardware requirements. Sierra was a fiasco, especially concerning PDFs.
PS: Not seeing an email yet. In DEVONthink, hold the Option key and choose Help > Report bug to start a support ticket and attach the video to that. Thanks!
