Hi,
I would like to achive this:
- Adding webloc bookmarks to my Inbox will convert them into webarchives automatically
- This works with “On Import” event
- Delete the webloc file
- This also works within the same smart rule
- Moving the new webarchive automatically into a folder
I tried it with a second rule that looks for webarchive files in the Inbox, but the “On Import” event seems not to trigger when the webarchive file is added by a rule. It works only, when I manually add a webarchive file. My workaround is to trigger the rule by “On Sync” but with this I have to wait some seconds.
Any ideas?
