DT4 Beta1 - Issues with markdown editor
Hi,
I have some issues with markdown editor in Beta1 of DT4.
It will be hard to explain it by writing, that why I recorded videos showing the issue.
I was not able to put the videos on this port. I uploaded them in the link bellow:
http://u.pc.cd/OrEitalK
Important:
I did try the same actions on DT3, it is working fine.
Thanks for the screencasts.
Is this on macOS Sequoia?
PS: The window with the sidebars on the left is a main window. A document opened on its own is in a document window. Just so you know the official terms. :slight_smile:
Yes, Sequoia
Thank you for updating me on the terminology of main window vs document window :blush:
Nice machine and you’re welcome!
PS: The current version of macOS Sequoia is 15.4 . You should update your machine and stay current with the operating system point releases.
Here what I did :
  • Before upgrading to Sequoia 15.4, I restarted the Mac, just in case. But, The issue was still there.
  • After the update to 15.4, the issue is gone (for now). If the issue come back, I will update this post.
Sounds good!
A copy of the document would be great in this case too, thanks in advance.
