Hi,
This one is hidden away on a panel I don’t often use, so it’s taken me some time to find it – sorry for the delay in reporting…
In the Inspectors > AI > Tags panel Add All ^A button the short cut ctl-aseems to be hardcoded, which means that it overrides the standard MacOS built in text shortcut for beginning of line (Ctl-a). This is a problem for those of us who use this shortcut all the time…
This sort of thing – accidentally overriding built in MacOS text shortcuts – happens because there are only so many shortcuts to go round and in some ways it’s understandable.
Normally I just hunt the errant shortcuts down and override them in System Settings. So, for example, I change Tools > Inspectors > Properties from Ctl-p to something else, because Ctl-p is a standard MacOS text shortcut for previous line and it really should be reserved for that purpose.
But in this case, Add All ^A seems to be hard-coded and it’s not accessible to System Settings to override.
Please could a future version either a) change the shortcut or b) make the command accessible from the standard menu system so it’s changeable in System Settings?
Many thanks!
