Dear Devonthink Team,
I’ve been trying out the new Graph View in DT4 V4.0 beta 3 and really appreciate the direction it’s heading. It’s a highly promising addition that significantly enhances the visual exploration of note interconnections, especially in Wikilink-heavy databases.
I noticed that the number of nodes displayed in the Graph View seems to be capped at 20. Even when a note links to more than 20 others, only the first 20 — or perhaps those with the most mutual cross-links — are shown. I’m wondering whether this limit is intentional, or if it might be adjustable in future versions. In my case, working with densely interlinked notes, having the option to raise this limit would make the Graph View far more useful.
I’d also find it helpful if there were more settings available. In particular, the ability to adjust node size and/or text size would help reduce visual clutter, which currently becomes an issue when many nodes are present in the graph.
I think these kinds of improvements would make the Graph View a lot more practical for managing complex note networks.
Thank you for your ongoing work and consideration ![]()
