The problem
text
is converted to
rich text
Steps
Open new smart rule
Paste the following code into the text field
text 2 thru -1 of theText
- Click on the “eye”
In the end the code is converted to “rich text” which fails to compile.
The complete code of the function:
on trim(theText)
if length of theText = 0 then
error "Can't trim empty text." number -1728
else if length of theText = 1 then
return ""
else
return text 2 thru -1 of theText
end trim
Development would have to assess this but there are two types of texts in DEVONthink: plain and rich texts.
But why are you using texts
here instead of e.g., characters
, text items
, or words
i guess one is a synonym of the other.
I misread that earlier as texts
but development will still have to assess it. characters 2 thru 1 as string
functions in the same way, so I’d opt for that.
text
was always rich text and therefore a lot of scripts using as text
(or some other form of text
) actually should have used as string
(as string
is plain text) and/or didn’t work as intended. This is more obvious now and avoids also some syntax conflicts of the former script suite.
Found an example on the internet and it worked as expect.
rich text fails
String is replaced by strings
The syntax is in both cases not correct, use the one suggested by @bluefrog instead:
characters 2 thru -1 as string
