I have been using DTPro intensively for several years for information gathering, in several projects.
I use a database for each category of projects. For instance:
project categories
- non-profit
- writing
- training
- personal development
What I appreciate, is the robustness and reliability of DTP, as well as its capacity to synchronize between different desktop machines (for me: Mac Mini and MacBook Air, over Dropbox). Unfortunatly, DTTGO, which I have purchased, isn’t as reliable (some database are reluctant to synchronize) nor convenient (the note taking interface is just too basic).
Recently, I have upgraded to DTP Office in order to be able to manage systematically bills from our non-profit, as well as scan occasionnally info page (can work well with newspaper articles, when they are not too large).
I usually manage a couple of projects at the same time, typically 2 or 3 professionnally, and a few writing projects. I have recently customized the Project template to my own needs, and it works. Additionnally, I have added the Annotate and Revision scripts, which I found a bit difficult to customize.
I would appreciate if there could be some notion of dates in the folders and files managed in DTP (such as deadlines). I could do that in invoking reminders, but seems like fragmenting projects into bits. Instead, I am looking what project management software I could use that would interface well with DTP Pro, allowing for instance to refer to larger notes / docmentation. I’ve tried Omnifocus, but it is to individual for me, as I want to be able to share my project with a small team (less than 10 people). If you have any insights on how to articulate DTP usage with project management, please tell me.
Overall, DTP is great for large information management, finding information, for writing projects. I do need to articulate it with a project management software, desktop or online, to make it my one-only work landing point.
PD. Why does the list appear as it does above?
