DTTG not syncing with Dropbox
Hi, I just purchased DTTG and intend to sync it with DTPO via my sync file on Dropbox. I already do this successfully between two computers with DTPO, but when I’ve tried this with DTTG and click on the cloud icon it says “Preparing…” and the status bar never completes. I’m guessing I haven’t properly connected to my sync file on Dropbox, but I can’t quite discern what I’ve done incorrectly. Any thoughts?
Did you already import the databases to iOS or is there no data in DEVONthink To Go 2 yet?
No, I haven’t tried to import the database. Is that something I need to do first?
Thanks.
Yes, you have to import the databases that you want to use on the device first.
Go it, thanks!
