I haven’t looked at my tags on DTTG recently, but was perplexed when the tags didn’t show in the info panel, even though they are present back at my Mac.
To test, I just created a simple text file in DTTG and added a pre-existing tag manually. After saving, the new note did not show any tags in the info panel, and the note did not show up in the pre-existing tag group on DTTG. It did, however, create a new tag group with the same name and the new note is there.
After syncing, everything is as you would expect back at my Mac. The new note shows the tag in the info panel and it has been added to the original tag group.
To summarize the new note doesn’t given any indication that it is tagged in the info panel, even though it actually is tagged, albeit in its own new instance of the tag group.
Thanks, Paul
DTTG 3.8.11 (17488) - iOS 18.5
DEVONthink 3.9.14 - Sequoia 15.5
