The error only occurs when triggered by the once a minute trigger. When I run the rule manually, I don’t get a timeout. I don’t know why. Something must be different when running the rule by the one a minute trigger.
Have you tried running a rule with a javascript script using the once a minute trigger?
I tried to re-create your setup: A smart rule (in my case, selecting all documents in the Inbox) that is run every minute. The only action is an JavaScript. I do not see any error messages re time out.
I’m also unable to reproduce any timeout here either.
Select, Control-click, and disable the actions of other smart rules.
Do you see the timeout again?
@Lynx have you seen this behavior lately? I’m thinking I’m experiencing the same problem and wondering if you’re still having this issue: Timeout with performSmartRule
@mdbraber I’m still facing this issue. I thought it was a problem due to my local system, because no one could reproduce it. My workaround was setting the trigger of the rule to After Synchronization .
Is the smart rule only triggered every minute or also used by e.g. other smart rules and/or scripts? Does the rule maybe process huge documents and/or are the databases/documents located on a slow network volume?
Does it work after disabling the actions of all other smart rules temporarily (e.g. via the contextual menu of the sidebar)? In addition, please choose Help > Report Bug while pressing the Alt modifier key and send the result to cgrunenberg - at - devon-technologies.com so that we can have a look at the logs - thanks!
