I’m trying to set up a sync using iCloud CloudKit. I get error message: Error while setting up location “iCloud (CloudKit)” CKErrorDomain 2. Is my computer too old to set this up? OS 10.12.6 Currently have Bonjour Local running. I see the SyncStore.dtCloud folder on iMac. I’ve been referring to the manual but can’t locate troubleshooting for this. Thanks in advance
At least the forum is full with error reports concerning some kind of CKErrorDomain or another. They’re mostly due to the unreliability of Apple’s cloud software.
If you’re using Bonjour anyway and that works for you, why do you want to switch to (or add?) iCloud sync?
