DTPO imports Evernote-Notes directly, but if you have a lot of documents that have been scanned as a JPG, you loose the possibility to search these documents .
Evernote permits the search, but don’t let you migrate the OCR-text.
It is not possible to OCR again such documents in DTPO, as it doesn’t permit to handle the imported JPG as an image and push the OCR-Button.
Thanks to a forum user, ifound this service:
cloudhq.net/
Their servers sync between several cloud services (Evernote, Dropbox, Google Drive…).
After signing on and after permitting them to connect via API on your databases, you can program syncs like “Oneway Sync : every Evernote Note in the notebox xyz -> transform in a PDF -> put in in a folder xyz on Dropbox.” I unchecked every other import form, so every note has been transformed in a PDF.
When syncing is finished and your computer has retrieved the Google Drive -Content, you can drag and drop the PDFs in DTPO and OCR them (select all, OCR).
This works pretty good, i had "only 78 documents with a sync error of the first 3000 notes that i synced in this way. Will continue all syncs and report here in the end.
I had to choose “Google Drive” and not Dropbox, although Dropbox is much more reliable than Google Drive, but Dropbox replaces the timestamp of all documents with the date of the sync. This because of the API of dropbox that doesn’t permit keeping the date, the CloudHQ-support said.
With Google Drive, your documents keep the creation date.
If other users go this way, i would be happy to hear how it did work.
