I’m new to DTPO, and I’m wondering if it is possible to export RTF notes with their tags visible in the document body.
The reason I’d like to do this is to be able on occasion to print out (yes, print!) the notes with the tags visible so that I can sort them manually.
I’d be grateful for any help or guidance about this.
You could duplicate the documents, afterwards use this script to insert the tags and finally export the copies:
-- Insert tags in text. Requires split, column or 3-pane view.
set theWindow to think window 1
if type of theRecord is rtf or type of theRecord is rtfd or type of theRecord is txt then
set theTags to tags of theRecord
set {od, text item delimiters of AppleScript} to {text item delimiters of AppleScript, ", "}
set theTags to theTags as string
set text item delimiters of AppleScript to od
if theTags is not "" then
set the selection of theWindow to {theRecord}
tell text of theWindow
make new paragraph with data ("Tags: " & theTags & return & return) at beginning
tell theWindow to save without asking
