In list views of bookmarks and web archives, it’d be great if the icon were the favicon for the site, rather than a very tiny thumbnail or generic “web page” icon.
Thanks for the suggestion. First request I’ve seen.
DEVONthink “bookmarks” are standard OS X .webloc plists, which store only the URL of the site. There were some old OS X utilities (“Faviconic” or something like that, IIRC) that set the icon of the .webloc to the favicon. I don’t know if those apps are still around.
But DEVONthink is currently able to display a thumbnail as an icon, right? Where is that stored, and wouldn’t that mean an icon could be stored as well?
You can create thumbnails for bookmarks via Data > Thumbnail.
Just for the heck of it: Here’s a JXA script that sets the thumbnail of the currently selected bookmark(s) to the favicon of the site (if there is one). It recognizes link rel="icon" elements in the HTML head, “favicon.*” images and images ending in “.ico”. The first one found is set as thumbnail.
NOTE: This script can not be used in a smart rule (yet), since JXA in DT smart rules is still broken. A fix is announced for one of the next DT versions.
const records = app.selectedRecords.whose( {_match: [ObjectSpecifier().type, "bookmark"]})();
records.forEach(r => {
let favicon = "";
let found = false;
const URL = r.url();
const domain = URL.split('/').slice(0,3).join('/');
const HTML = app.downloadMarkupFrom(URL);
const embImages = app.getEmbeddedImagesOf(HTML, { baseURL: domain});
if (embImages.length > 0) {
for (let img of embImages) {
if img ends with ".ico" or img contains "/favicon"
or img is part of a <link rel="icon" ...> element in the header, then
set favicon to img
exit loop
found = /favicon|\.ico$/.test(img) || RegExp(`<link.*rel="icon".*${img}`).test(HTML);
if (found) {
favicon = img;
break; /* exit the loop here */
if (found && favicon !== "") {
r.thumbnail = favicon;
Here’s a slight tweak / update working with DT4… (I was getting errors with the use of ObjectSpecifier().type). Thanks for the original ![]()
const r = app.selectedRecords();
const records = r.filter(r => (r.recordType() === "bookmark"));
let favicon = "";
let found = false;
if (found) {
favicon = img;
break;
whose still works. But as you noticed, there has been some changes to the scripting dictionary and type is now recordType. So it’s ObjectSpecifier().recordType:
const records = app.selectedRecords.whose( {_match: [ObjectSpecifier().recordType, "bookmark"]})();
In case of AppleScript type still works in most cases as it’s a synonym of record type and as DEVONthink 4 includes additional internal workarounds to make this as compatible as possible. Only JXA definitely requires updated scripts.
