The “File Using @ Destination” Script is helpful. However when I place it in a Smart Rule and execute it several times with the same @Destination, a new Group is created each time (with the same name). It is possible for subsequent items to be placed in the same group if the @Destination is the same?
It’s not only possible, that’s the behavior.
- A new group is created where ?
- What is the @Destination ?
- Do you have more than one gorup with the destination name?
The destination does not previously exist; it is created by the Smart Rule.
This is my Smart Rule:
Before Running Smart Rule this is in my Global Inbox:
After Running Smart Rule on these two items:
The script is not compatible to groups being also tags (option Exclude groups from tagging disabled). The next release will change this.
