I’m new to DEVONthink Pro Office, but am in the process of using it to make my home office relatively paperless.
I have setup a “hot” folder using folder actions so I can just drop a file in and have it imported and OCR’d and then have the original file deleted. That part works fine.
What I am hoping to get some help with is the filename. When I drop a file into the hot folder I would like DTPO to keep that filename, but it doesn’t. So, for instance if I drop the file “Morgan Stanley_YTD 2012.pdf” into the folder, DTPO imports it as “Morgan Stanley Document”. Is there a way to have DTPO keep the original filename? Thanks.
I have a similar folder set up on my desktop but haven’t used it in a while. I presume this is a bug? I can’t see any reason to have anyone/anything other than the user change the name of a file on import.
I’ve used AppleScripts only a handful of times, so it’s not an easy enhancement for me. Would you happen to know what code I would need to add to the script to have it preserve the file name?
