Hi Folks,
quite recently the window to fill in metadata after import from my ScanSnap is not popping up any more. I cannot pin point it directly but I believe this happend after the last Update of DTP.
Nothing has changed in my set up, afaik no update of the ScanSnap software. I am using an older model with ScanSap manager 7.2 L60.
The imported files show up in my general inbox (set in preferences) fine with OCR applied, but keep their generic file names as set by SanSnap software, I am sending everything directly to DTP (3.9.3), not to the Inbox folder.
the “fill in metadata after import” checkmarkj is SET in prefs.
This is difficult because it is much easier to use the metadata window than in the navigator side panel.
What to do now?!
Cheers,
Rolf
