@mbbntu Thank you for mentioning this. Very interesting! I’ll take a look at the other conversations you mentioned.
wow…the sorter itself sold me on DT. Huge for me…quick not only to write a note, but to send it where I want and keep moving.
The sorter is central to me. It is my note taker now. If I had to rate features sorter would probably be the most important one. It is also important to me that I can run it totally from the keyboard. I always put notes in the same place and then move them from there ‘one day’.
If a floating sorter is at all a possibility, it would be very welcome!
I’m not sure if it’s just my use case, but it would be wonderful if the sorter itself was floating, vs the fixed positioning options.
Right now I still have the sorter disabled to get the ‘take notes’ to float.
Thanks!
@Cali310 There is software that makes every DT window float. The sorter window is too wide for me, but not high enough.
I can adjust the size and position of the DT RTF window as I wish. That is more practical for me. I have a blue border displayed for floating windows, which is customizable.![]()
Which software are you using to float DT windows?
