Global Inbox sync problem
Hi everyone,
When I open a PDF on my iPhone and press “Open in DEVONthink”, the file gets imported into the Global Inbox.
Later, when syncing (one DB with Bonjour, the other over iCloud), the file in the Global Inbox doesn’t get synced to the Global Inbox on my Mac.
Only when I move the file to the Inbox of one of the DBs, then the file appears on my Mac in the specific Inbox.
How can I assure that the files in the Global Inbox get synced as well?
Are you actually syncing the Global Inbox ? It requires you to set that up.
Oh ok. I guess I wasn’t aware of that.
I just used the AI search of the manual but didn’t find any suggestion. Or am I blind? :sweat_smile:
Looking into the settings … could it be, when clicking on iCloud the database “Eingang” (Germano for Inbox)? Does it refer to the GLOBAL inbox?
OK, I think I got it.
In the DTTG sync I found the sync setting for the global inbox.
Could you please only help me to understand what will be synced when activating in DT the “Inbox” sync in iCloud?
The contents of the Global Inbox, no different than how it syncs any other database.
