Hey! I recently set up DT in my new Mac Mini - Sequoia. Every once in a while, the Go To Group command (either clicked or keyboard shortcut) stops showing up the pop-up selector. Restarting DT fixes it for a while, but it stops working again without any clear pattern.
Any ideas? Thx!
Please choose Help > Report Bug while pressing the Alt modifier key and send the result to cgrunenberg - at - devon-technologies.com - thanks!
Thank you for the logs! “Unfortunately” no unusual messages in the logs, everything seems to be working as expected. A screenshot right before using Go > To Group… might be useful.
I am getting the same problem now. The keyboard shortcuts (Control+Command+G) doesn’t bring up the pop-up selector. I have double checked App shortcuts and Keyboard Maestro to make sure no conflict.
In fact, selecting directly from menu Go>To Group… is also not working. Go>To Document works though.
Just to add. Restarting DT will fix it. And after a while, it stops working again. No clear pattern when it will stop working.
I have figured out what I did that cause it to fail.
If I open an item/document, when I press (Control+Command+G). It will fail. Even when I go back to the main window, the (Control+Command+G) will fail. In fact, the menu Go>To Group.. will fail.
DT4beta3, macOS Sequoia 15.5
I have emailed the bug report to you.
I couldn’t reproduce the hotkey not working.
@cgrunenberg : However, if I open a document in a document window and press the shortcut, the popover appears unattached to the toolbar…
Closing the document window shows it is indeed floating.
That’s intentional as document windows can’t go anywhere.
