Graph - Tags connection
For some documents i cannot view the tags connection in the Graph as i cannot enable the option “tags” in the view connection panel despite many tags are assigned to the document) for some other documents it works fine …. the options “See also” and “mentions” are always enabled … I dont understand why its only for some documents that i cannot enable the “tags” connection ….Ty for your help
I tried to convert the Markdown document to RTF and PDF adding the same tags …. and it works fine the tag connection is enabled so it seems teh issue is only with markdown documents
The type of the document doesn’t matter actually. Are some of the tags only assigned to this document?
Yes right, noticed the type does not matter. Yes some of the tags only assigned to the document, very often i use phrase as tags
if on the document i choose only tags that are assigned to another document then it works ! does it mean a document with unique tags will prevent the use of using “connecting tags” ?
Tags are usually only used if the document shares tags with other documents. In addition, the number of nodes shown by the graph is limited and tags have the lowest priority.
Noted
Is there a hard number for this Christian? ie: 20, or is it dependent on other factors?
It’s a hard-coded limit so far.
