I’m having a problem when running Scripts and maybe some wizard from this forum can help me.
My problems:
None of the Firefox Scripts works (Add link to DEVONthink; Add web archive to DEVONthink; Add web document to DEVONthink), and I get the following error message: “No browser is open/in front”. I’m using Firefox 3.0.5. (I checked the Safari scripts, and no problem there.)
When running the scripts for NetNewsWire (Add flagged news to DEVONthink; Add news to DEVONthink) from the menubar Scripts menu, I have the error message “can’t get ‘class Titl’ of ‘class SeHe’”… However, if I open Script Editor and run the scripts from there, they both work. Weird.
The first one is not critical, since I can use the DTP Bookmarklets. But I really miss the NNW scripts working properly.
I don’t use FireFox, so I can’t help you with that one.
However, I do use NNW and the scripts are broken as you discovered. This has been reported as a bug, so I would expect that it will be addressed in the future.
If you mean the scripts available for captures from Firefox when it’s the frontmost application, all of them work here, for capture of the viewed page as WebArchive, PDF or bookmark.
sorry, no I was talking about the netnewswire scripts for both flagged and selected news.
In reality though, I’m not sure why I would choose NNW over DTPO as my primary newsreader. Is there a way to import my hundreds of feeds other than one by one?
I just tried out of curiosity and got an error like:
cannot make “” into type boolean
(or something to that effect). It seems like this was a precedence issue; for the “add news to dt”, I fixed it by adding 2 pairs of brackets and the script is now:
tell application "NetNewsWire"
if exists selectedHeadline then
set this_headline to selectedHeadline
set h_title to title of this_headline
set h_URL to URL of this_headline
set h_enclosure to enclosure URL of this_headline
if exists date published of this_headline then
set h_when to date published of this_headline
else
set h_when to date arrived of this_headline
if exists description of this_headline then
set h_note to description of this_headline
else if exists summary of this_headline then
set h_note to summary of this_headline
else
tell application id "com.devon-technologies.thinkpro2" to create record with {name:h_title, type:bookmark, date:h_when, URL:h_URL}
return
if (exists h_enclosure) and (h_enclosure is not missing value) then
set h_note to "<html><body><p><a href=\"" & h_URL & "\"><bold>" & h_title & "</bold></a></p><small>" & h_note & "</small><br/><a href=\"" & h_enclosure & "\">" & h_enclosure & "</a></body></html>"
else
set h_note to "<html><body><p><a href=\"" & h_URL & "\"><bold>" & h_title & "</bold></a></p><small>" & h_note & "</small></body></html>"
tell application id "com.devon-technologies.thinkpro2" to create record with {name:h_title, type:html, date:h_when, URL:h_URL, source:h_note}
else
error "No headline is selected."
if the error_number is not -128 then display alert "NetNewsWire" message error_message as warning
I have no idea if this is what the others also had. I can fix the other too if you need it (I don’t clip things from NNW to DTP so didn’t bother).
