Hi,
I can’t believe that I actually did this but I accidentally trashed ~hundreds of files in Easyfind. I was searching for “ape” to remove any trace of unsanity haxies and a huge list resulted. I used the commmand+delete keys without thinking and now I have no idea where many of these files belong. Undo did nothing within Easyfind.
Does anyone have a suggestion to restore them to their rightful places? :-[ >:(
thanks
Edit:I ended up running another search on a similar volume, comparing those files with the ones I trashed and then reinstalling some files manually and some apps entirely.
Ugh.
