Hi, guys!
I’d like to export copies of records to Bookends. The current script, however, doesn’t send copies of records to Bookends, but deconsolidates (move) the records to Bookends.
Could you please help me adapting the Script, so I can have the files both in Devonthink and Bookends?
I copied the original script below
type or paste code here
```tell application id "DNtp"
set theType to type of theRecord
if theType is not group and theType is not smart group and theType is not feed then
set thePath to path of theRecord
if thePath is not "" and thePath does not contain "/Documents/Bookends/Attachments" then
set theURL to URL of theRecord
set theNote to comment of theRecord
set theDate to creation date of theRecord
set theYear to (year of theDate) as string
set theMD to meta data of theRecord
set theCustomMD to custom meta data of theRecord
set {theAuthors, theKeywords, theDOI, thePMID, theISBN, thePublisher, theJournal, theVolume, thePages} to {"", "", "", "", "", "", "", "", ""}
set theAuthors to my metaDataItems(|kMDItemAuthors| of theMD)
set theKeywords to my metaDataItems(|kMDItemKeywords| of theMD)
if theKeywords is "" then
set theKeywords to tags of theRecord
set theKeywords to (theKeywords as string)
set theDOI to mddoi of theCustomMD
set thePMID to mdpmid of theCustomMD
set thePublisher to mdpublisher of theCustomMD
set theJournal to mdjournal of theCustomMD
set theVolume to mdvolume of theCustomMD
set thePages to mdpage of theCustomMD
deconsolidate record theRecord to "~/Documents/Bookends/Attachments"
set {od, AppleScript's text item delimiters} to {AppleScript's text item delimiters, "/"}
set theFilename to text item -1 of (path of theRecord as string)
tell application "Bookends"
tell front library window to make new publication item with properties {title:theName, url:theURL, notes:theNote, keywords:theKeywords, authors:theAuthors, pmid:thePMID, doi:theDOI, isbn:theISBN, publication date string:theYear, publisher:thePublisher, journal:theJournal, volume:theVolume, pages:thePages, attachments:theFilename}
on metaDataItems(theString)
if theString is not missing value and theString is not "" then
local od, theItems
set {od, AppleScript's text item delimiters} to {AppleScript's text item delimiters, "," & (ASCII character 10)}
set theItems to text items of theString
set AppleScript's text item delimiters to ASCII character 10
set theString to (theItems as string)
return theString
return ""
end metaDataItems
