BIBLE VERSES with a specific style: I write a simple model in markdown that mentions:
a) Verses name
b) verses text
c) verses in greek
d) text list of comment author (each text has a Devonthink link)
e) notes of translate author
f) Aliases (eg. Mt 5.5 was refer also in Lc 5.6)
g) Wiki Linking (if possible define it as a wiki, so when I wrote Mt 5.5 link it directly)
TEXTS with a specific style: I write a simple model in markdown that mentions:
a) Text title
b) Numerical paragraphs
d) Links to the previous verses (eg. Mt 5.5 link to this verses)
e) Aliases (Mt 5.5)
You probably need someone who knows markdown and regex and reference materials, perhaps @Bernardo_V may be able to help when he reads your post. Obviously, @BLUEFROG is always here to support us.
Today I focus on create bible verses using markdown. What I want is select a text and create a new markdown using the title that appears in the beginner.
A short cut or a service to create this markdown show be great, because I don’t have it im my system.
I would like to know how can I use markdown templates using text in transfer area.
And I would like to modify this input text to turn it in this style (because I need to remove the old number references, in this example the numbers 303 and 304).
To me this seems way too complex for a single simple solution. Perhaps the documentation could help (e.g. the section on wiki links)? Also, Multimarkdown Composer has a really nice Syntax Cheatsheet which could be helpful.
