I am trying to write a script which includes opening a document or group in a new window (equivalent to double-clicking a selection.) I cannot find the syntax to open a new window from a selection however. I have tried the following code:
tell application “DEVONthink Pro”
activate
set theSelection to selection
open viewer window of theSelection
This generates the following AppleScript error:
“Can’t get viewer window of {record id 10438 of database 1 of application “DEVONthink Pro”}.”
I would also like to set the view-style once opened.
This script will open a window for each selected record (as does command-O). To set the view style of group windows you will need to use GUI scripting. Make sure you have GUI scripting enabled by selecting “Enable access for assistive devices” in the Universal Access preference pane.
activate
set selectedItems to the selection
repeat with z from 1 to count selectedItems
open window for record (item z of selectedItems)
if type of (item z of selectedItems) is group then
if UI elements enabled then
keystroke "2" using {command down, option down}
delay 1 -- optional, may depend on the mood of your computer :-)
Thanks. That works great. How do I code if I want to open a window of a record by the name of the record and not by selection? I am still having problems with the syntax for specifying a specific record to take an action on.
Some examples (you must fill in the correct names of the records you want to open):
-- record at root level
open window for record (record "recordName" of database 1)
-- record of a group located at root level
open window for record (child "recordName" of parent "groupName" of database 1)
-- record located two levels deep
open window for record (child "recordName" of child "groupName(2. level)" of parent "groupName(1. level)" of database 1)
Ahh… so the trick is to use GUI scripting, which I’m surprised is necessary considering how scriptable DT Pro is. Thanks for that tip and the sample script!
