Hello
I had a very disturbing experience last night. I was getting the errors shown in the attachments below.
I had one item that would cause DTO to crash every time I tried to open it up. I had to force quit DTO every time I clicked this file. Since I did not feel it was that important, I went into my db via “show Package contents” and eventually deleted the bad file". I could not right click to “show in finder” since it would crash DTO. Upon running DTO, I got the errors seen in the attachments.
After I deleted the file per above, I found the bad file in a folder labeled “orphans”, There were also two other items in the “orphans” file which I did not manually touch.
I figured I probably should not have used the technique I tried to delete the bad file.
Verify and repair seems to give NO errors now. And the db opens and works fine.
If this happens again, how and what do you do? Does I still need to run “rebuild database”? I have not done so.
Thanks
Kim Marietta
Snow Leopard 10.6.4
2.8 GHz Intel Core 2 Duo
4 GB memory
Mac Book Pro
Fujitsu S1300 Scanner
DTPO 2.0.6
