I don’t know if many of you use Mind Node, but they have recently removed the share shortcut from their app. I previously used this to save documents to DT it was a one-click operation & really easy. I have raised the issue with the developer but they do not seem interested in restoring the share option. They have suggested using a shortcut, but it seems to generate a link rather than a copy of the current document. I have no facility with AppleScript or Automator so am feeling a bit stuck. Does anyone have a script which can send a copy of an open Mind Node document to the DT inbox? I’m quite happy to do this via the Services menu.
I think I might have to go down that route, thanks. I have overwritten previous meeting notes up till now because I could save them so easily into DT. Isn’t “progress” a wonderful thing!
So you weren’t creating versions. If you were overwriting meeting notes intentionally, why not just put a MindNode file in DEVONthink, open it externally when needed, and make edits?
You can also save a MindNode document into your DEVONthink templates to quickly make a new one, then open it externally for editing…
It’s probably pretty poor practice but I do this with a few documents. With MN I create documents with the same title to keep notes of regular meetings. When I am done I share the version to DT. Next time the meeting comes round I create another document with the same name which over-writes the one I have saved in the folder in iCloud. That way I can use tools I enjoy & not clutter up my document folders. Mind Node is great for keeping informal notes of the meetings I attend as they are rarely linear.
