Hello all,
I’m actually embarrassed about popping up this question – it’s something that should be so simple, but I am having endless trouble trying to get it right.
It once again confirms how much I still have to learn about ‘simple’ programming concepts – since (in my head) a ‘search-pattern’ sometimes ends up feeling like I’m trying to programme something…
All I want, is a smart group that will watch my DB, looking for:
1.) EITHER plain text or RTF files
2.) That contain EITHER “Term A” or “Term B”
OR
3.) Are tagged with “Tag A” or Tag B"
My Search pattern is as follows:
1 [ANY] of the following are true
2 [KIND] [is] [Plain Text]
3 [ANY] of the following are true
4 [CONTENT] matches [Term A Term B]
5 [TAG] is [Tag A]
6 [TAG] is [Tag B]
7 [KIND] [is] [Rich Text]
8 [ANY] of the following are true
9 [CONTENT] matches [Term A Term B]
10 [TAG] is [Tag A]
11 [TAG] is [Tag B]
With the above set, the following files are pulled into the Smart Folder:
a.) Doc AND Docx files –– which I would dearly like to EXCLUDE from the above, but since they are presumably deemed Plain/Rich Text files, I’m struggling to work out how to do that.
b.) PDF + Text files.
c.) 2700 odd RTF files that are inside my DB ℅ the “Import from Bookends” feature.
Some random other files, including Scrivener files.
Obviously the search function is not running in the same manner I envisaged.
I’m clearly lacking some quality [facepalm] moments – so would appreciate some clarification on what I am fundamentally misunderstanding about the search-pattern >> no doubt falling apart where I start nesting things…
Lastly – for what I need, should I avoid the smart-group all together, and rather work off a saved advanced search run, which can be saved as a smart group as well?
