I’ve read many highly informative threads on these forums on how to go about syncing a Devonthink database between two computers, and with each one I read I become even more confused than I was before. I’ve also watched the tutorial video on syncing, and the same is true.
Current Problem & Desired Outcome
I have a 20GB DTPO database stored in my Dropbox folder so that I can access it from my MacBook and my iMac, and I have been using Dropbox to keep this database in sync between the two machines (making sure not to have the database open on more than one machine at the same time). I KNOW THAT THIS IS HIGHLY FROWNED UPON AND IS A RECIPE FOR DISASTER, so once and for all I’m trying to figure out how to go about setting things up so that I can sync “properly” using Devonthink’s built-in sync capabilities.
Where My Confusion Lies
I am unclear as to which sync method (or methods?) I should be using.
• Should I authorize my Dropbox account in the sync preferences of DTPO on both my iMac and MacBook computers, and then specify that I want to sync my database using Dropbox?
• Do I add a new Local Sync Store and save it to ~/Dropbox/Apps/DEVONthink/.
• Are sync methods meant to be used in combination with one another (such as setting up a Direct Connection sync to speed up syncing my between my laptop and desktop machines while they’re both on the same local network.
Misc Bullet Points:
• I understand that the actual Database.dtBase2 file needs to be stored outside of my Dropbox folder… that much I’ve got.
• I’d like to be able to sync my database in/out of my local network.
• I’ve got 100GB of Dropbox strorage space, so keeping my 20GB Devonthink database in Dropbox isn’t an issue.
• If possible, I’d like to avoid having to re-upload/download my existing 20GB database to Dropbox’s servers, which would take several days. If it somehow simplifies the process if I do so, that’s fine I can just suck it up, but I’d rather avoid going there if possible.
• Worth noting… when I say I’d like to 'Sync my Database" what I mean is that I’d like to be able to fire up Devonthink on either machine and know that any file I added to the database on one computer will show up when accessing that database on the other computer, and vice versa.
If you’ve made it this far, thanks so much for your time! I can’t wait to hear back from you guys with any helpful guidance you have to offer. Thanks!
**Please note… if I am wrong about any of this, please don’t hesitate to let me know, but please avoid extraneous details unless they help me accomplish my goal outlined above. Too much noise makes me want to jump ship… (by step #20 of this explanation ~ Syncing and database location/storage ~ my brain nearly exploded).
