How can I clean junk entries from Field memory?
I would like to clean up junk data memory in DT. Data is normally easy to enter when the software remembers my correct entries and hard when it remembers my errors.
I’m a stroke patient and sometimes my left hand hits multiple keys when entering data into fields. If I move on before noticing my error, I end up with junk entries in DT memory that’s offered to me the next time I try to enter data into that field.
Can anyone help me clean up these errors from DT’s field memory? Thank you!
Welcome @veepy2espy
Please clarify what you mean by “memory”. Are you referring to autocompletion suggestions for tags showing accidentally entered tags?
Yes, I guess that’s the right term. Thank you for asking.
Can autosuggestions be updated to remove errors?
I mean, can autocompletion suggestions that contain typing errors be edited to remove those errors.
Did you try removing the erroneous tags?
I have searched the application for any way I could edit or delete my errors, but have found nothing that sounds like the autocompletion suggestions could be acted on. I was hoping someone with knowledge about the internal design could point me in the right direction. Thank you.
A screenshot would be useful.
I described what you could try, and that did not involve any searching nor editing. Here’s a series of screenshots illustrating how to get rid of erroneous tag entries. Perhaps that helps.
Enter a wrong tag.
Check the database’s tags group in the left sidebar – the unwanted tag is there.
Try tagging a record – DT suggests the wrong tag after I typed its first two letters.
Delete the tag from the database’s tags group.
Try tagging a record. DT does not suggest the wrong tag.
So that’s it for tags. If you’re talking about other “field”, you should tell us which one you’re referring to.
I’m building a database of receipts and documents now, so I am using several custom (metadata) fields for that project. When I select a field in the data inspector on the right side of DT (screenshot) and begin to type, a dropdown list of autocompletion suggestions appears showing examples of data I have typed into this field for previous records. When I type perfectly, This feature saves me hours of time during data entry. When I create typos and commit them to memory by tabbing to the next field, I get junk saved in the autocompletion suggestions. I would like to delete my errors before they get out of control.
So you were not talking about tags. Good to know. It would’ve bee even better had you provided screenshot(s) from the start.
Now we know that you’re fighting with custom meta data. But you do not show us how these are defined. It looks as if you were using a “Set” as a datatype here. But I can only select the pre-defined values in that case. Mistyping a value in this context is not possible.
Which begs the question how “Sta3ement” ended up in that list.
Thanks for that clarifying screen capture!
If you typed those in as ad-hoc entries, there’s no simple user-facing way to remove remembered entries. However, go into DEVONthink’s Settings > Data, choose your Record Type attribute and add default entries. This will effectively clear those other entries
You could also change this to a Set data type. This will limit the popup to showing only the values you define.
I was using Single-line Text as the custom metadata ‘Type’. You are very right about trying to anticipate the needs of others who are responding to my ask for help. Hindsight is 20-20, but if I need help again, I’ll need to be more helpful. Thanks for reaching out.
This solved my problem perfectly. Catching it now helps me avoid the issue going forward. Naming the specific values in a list was always there, but I failed to recognize it during setup. I hope this helps someone else as much as it has helped me. Thank you very much!
To summarize:
If anyone accidentally creates errors in their data entry fields that produce nonsense letters in DT’s autocompletion suggestions, then return to DT’s Settings > Data > Custom Metadata field of choice and use the dialog box on the right to add Values of your choice to overwrite the autogenerated list for the problem field. Kudos to BLUEFROG for the solution and also thanks to chrillek for caring enough to help.
"DEVONthink’s Settings > Data, choose your Record Type attribute and add default entries. This will effectively clear those other entries.
You could also change this to a Set data type. This will limit the popup to showing only the values you define."
Example 1:
Example 2:
Example 3 - solution:
My pleasure! Glad to help :slight_smile:
