How can I synchronise a smart group with DTPro?
Hello,
For my workflow over the summer holidays I would like to sync documents I want to read to/from DTTG4 Smart Group “Reading List” with the same Smart Group in DTPro. In other words, I want to synchronise the “Reading List” Smart Group on both devices. However, I cannot find the Smart Group “Reading List” in DTPro. The DTTG4 Smart Groups do not sync now. I don’t find any specific help in the DTTG4 documentation. I am not sure how to proceed.
I can’t find any recent and relevant posts on this topic. I might have missed them.
Any ideas would be appreciated
There’s no such smart group on the Mac, the reading list can be accessed via View > Sidebar > Reading List
And add to the previous response, the Reading List global smart group in DEVONthink To Go is the same as the Reading List in DEVONthink and they do sync.
Thanks!
Thanks. I don’t see “Reading List” with the other Smart Groups. Is that on purpose?
Post a screen capture of what you’re seeing.
This is what I see. No “Reading List” under “Smart Groups” in the left menu bar, and no “Reading Group” under Data | New from Template | Smart Groups.
The spectacles with a number in the left menu bar, I figured out, produce a list of the documents in the “Reading List”, but it lacks identification as a “Smart Group”. I assume it is the same thing
Am I missing something else?
The Reading List is not a smart group on the Mac, see View > Sidebar > Reading List
Ok, but if you read what I read (above) you can see I was confused about this. This is what I understand now: The Reading List is a Smart Group in DTTG and a View in DTPro. They are the same Reading List.
For ease of understanding and for adaptation for other uses, why not set it up the Reading List on DT Pro like a smart group in DTTG? I mean, DT software is complex, data is complex, and work processes and flow are also complex. Any way to reduce friction is good, no?
Thanks for the clarifications!
  • The Reading List in DEVONthink is intended as an isolated sidebar to allow for a cleaner place to review the items.
  • The Reading List is a global smart group in DEVONthink To Go as it doesn’t support multiple sidebars.
This is a matter of perception. Can it do complex things? Absolutely. Is it inherently “complex”? Not really. In 14.5 years, I’ve seen the gamut from simple databases to house user manuals and home inventories to highly coordinated, multi-database setups with automations doing many things in the process.
I wouldn’t call it a “complex” application; I’d call it an unusually “capable” one.
Work processes and flow are also complex.
This is not universal but subjective or potentially indicative of a less than optimal setup.
Good points. Capable, though, I find, doesn’t preclude complexity. A Rohloff 18-speed hub on my bike is capable and complex. The altimeter in the plane is also capable and complex. Most technology is. You might find the Z80 microprocessor architecture simpler than the M1 processor architecture, but for me, both are complex. Experience and abilities matter.
The subject’s (user’s) work process is always in development. Maybe towards more capabilities for s/he, but maybe not immediately–but maybe it is for others. Its development benefits from supportive exchanges.
We live with capabilities and complexities and mostly try to do things better. In software applications, it seems, diverse and helpful capabilities often go hand in hand with complexity, no? The user learns and applies. User feedback may offer insights to consider for future iterations of a software application.
In that sense, my message is simple: The Reading List capabilities in DTTG and DTPro are good. For me, the complexity of the different implementations reduces their capabilities. Maybe for others?
I share only my perspective.
