Hello,
I own an older iPad that, unfortunately, cannot be upgraded to DTTG4 due to iOS limitations.
Has DEVONtechnologies already decided how long the synchronization will remain functional?
I searched the forum for this information but was not able to find it. Right now, the sync still seems to work without any problems, which is great.
Thanks for any answer.
I can’t speak for them, but I don’t see why it would stop working. If you use features from DT 4 that are not available in DT(TG) 3, those won’t sync. Obviously. So, if you use audited databases in 4, you won’t have them audited in 3.
Revision-safe databases cannot be synchronized to DEVONthink 3 or DEVONthink To Go 3 (as this would be a simple possibility to bypass the protection & logging).
