Hi there,
Is there a way to access the Script Menu using the action “Select or Show a Menu Item” of Keyboard Maestro? I see all the menu items but Script…
Thanks for your help!
Hi there,
What are you trying to accomplish?
I would like to launch the “Daily Backup Archive” script with a trigger (for instance a keystroke, a specific time, etc.)…
Just set a DEVONthink-specific shortcut in System Preferences > Keyboard > Shortcuts > App Shortcuts.
It was too tempting to search for a much more complicated solution!
Thanks for your help @BLUEFROG
You’re welcome
