Does anyone know how to add a note to an entry?
Like a photo entry, or website entry?
I can’t find any way to do this.
Thanks.
Thanks.
There isn’t a uniform way to do this, as far as I can tell (and to my surprise, considering what this app is commonly used for).
There are elaborate (creative but quite inconvenient) work-arounds, such as making separate RTF notes and inserting links to the referenced item, possibly with a reverse link, and then grouping these RTF notes into a folder, and naming that folder for the original item. See Bill DeVille’s posts on “Annotations”, and the thread “Associate Notes with Reference Documents = Richer Functional”
Depending on the item type, you may be able to add very short comments in the “Spotlight Comment” or “Comments” field. Right click on a column in a list view, and expose the Spotlight-Comment field.
Sophie, thank you SO much for the response. VERY informative.
There has been a complaint in private from a Sr. Member that implies my threads and postings are idiotic and repetitive; basically, that I should RTFM instead of posting.
To address that, I will be posting a lot less in the future. And if I ask a question that doesn’t immediately get answered, I will mostly likely delete the thread a day later, so as to not unduly upset this Sr. Member.
I am really just a newbie here, so I guess some preference, accord, and respect should be given to forum members with seniority, no matter how abusive they might seem (to me). I am certainly the first to admit that I have only begun to learn the program. My apologies to any and everyone else who have found my threads and postings annoying and/or stupid.
To everyone in the group who has been kind enough to answer my questions and exchange dialogue with me to help me learn the program better, I extend my deepest thanks and gratitude.
–Sandy
Hi there,
in templates you will find a Annotation-template, that is made for annotations connected to a file.
You will find it in the Data menu >new with template >annotation
Before you use it you have to highlight the file you want to annotate.
The annotation will be saved in a separated Annotation-Group.
Agreed, and the forums here are generally very friendly and helpful.
This can be a deep topic. I’m struggling to find some previous discussion about adding “subdocuments” to primary ones, which seems related to the discussion in that other thread …
I recall a couple discussions about that. Probably not the same discussions, but I remember one about Scrivener’s ability to use documents as containers of other documents. Which is cool.
…, but I remember one about Scrivener’s ability to use documents as containers of other documents. Which is cool.
I vaguely remember that one, too, and agree it’s cool.
