How to copy raw Markdown links from WYSIWYG view?
The new WYSIWYG rendering of images and links is a great improvement, but I’ve run into a problem. I often copy timestamp links (e.g., [09:14](...)) from markdown annotation files to use in other markdown apps. Now, when I try to copy these from the rendered view, I only get the visible text like 09:14, without the underlying markdown link. Is there a way to copy the full raw Markdown syntax directly?
You can toggle WYSISYG editing by going to Format → WYSIWYG Editing.
Stephen
Inside DEVONthink that’s supported when copying from one Markdown document to another.
Thanks! Toggling off WYSIWYG editing does help. It’s a bit less convenient for general reading, but it works for this use case. Appreciate the tip!
Thanks for the clarification. Good to know it copies properly between dt files.
