I created a template. I followed the instructions about dragging the template on the toolbar given in a 2017 email (pasted below) but without success. Scrolling through the community posts I believe I add it as a shortcut, which would suit my purposes even better. But I don’t know how to do that. (If I could do both that would be even better.)
The other question: where is the ~library/support file to be found?
Thanks in advance for any and all assistance.
Add Templates to Your Toolbar
Do you find yourself using the same DEVONthink template over and over again? You may use our Project template often. Maybe it’s a custom Markdown document you’ve created. Or maybe it’s one of the templates for use with software like Bookends. Did you know you can add a template to the toolbar in DEVONthink? This is how…
Select Data > New > Open Templates Folder. You will see the Templates.noindex folder selected in the Finder.
Open this folder, hold the Command key and double-click the Toolbar folder to open it in a new window or tab.
Locate the template you’d like to add and move it to the Toolbar folder.
Quit DEVONthink and relaunch it.
Right-click the toolbar and choose Customize Toolbar…
Locate your template, drag it into the toolbar, and press Done.
