This is my first time using DEVONagent Pro, I want to know how to customize the search engine, the region, etc.
Update: I already found that how to customize the search engine, but I still don’t get a clue how to customize the region etc.
I’m not sure what you mean by ”the region” but have you looked at the built-in Help?
It is those results that relate to specific areas.
Specific areas of… what?
Are you referring to geographic areas?
In the area where I live, some search engines require a VPN to work, such as Google. I am able to set Google’s regions in Chrome to get results that are more relevant to me.
You could try using a Web (Express) search.
Sorry, I still don’t quite get it. Could you be a little more specific?
Click the magnifying glass icon in the search field and choose Web > Express.
Hi, I realise this post is now a few years old, but wondering if you were ever able to find a solution to this without having to use Web > Express? I’m located in Australia but I’m hoping to search Google AUS, Google UK, and Google US plugin’s through DEVONagent separately.
The only possibility would be to duplicate the Google plug-in and to customize the duplicates by changing especially the EngineURL value for the AUS, UK & US plug-ins.
