Claude
1
Hi,
When I started working with DT and DTTG, I created a few test databases with my smartphone and synchronized them with WebDAV.
How can I delete them now? I deactivated them in DTTG but they still appear in the DT Preferences/Sync window under remote databases.
Thanks for your advice!
In the right panel, right mouse click on the database and pick “Clean Database”. [Not sure why the term “clean” is used, but there you go.]
See more in the “Help” article “Synch”.
Claude
3
It’s working, thank you @rmschne, I couldn’t find it in the documentation.
