I have been using the “import to selected group” folder action script with the 2.x version of DT all this time. With DT 3.x when I drop files onto the DT icon I get a dialog box which allows for filename changes and selection of destination group. See image below. Is there a way to get this dialog box with filename field using scripts? The earlier script command said "set theGroup to display group selector"
Thanks again. I have the script and it works for me as well. However I want it to show the exact same dialog box as in my initial post (where filename field is provided and editable). The dialog box coming from this script doesnt have that field at all.
My issue is that when I download multiple pdf files for my research, i get same number of the dialog pop-ups and without the filename. So i am not able to decide which group I want to drop that file into DT. If the filename field gets displayed I can make a better decision. Hope I clarified
