How to insert link to a Bear Note into a DevonThink document
I tried all possibilities I could think of but nothing work. thank you
What possibilities have you tried?
I found the problem. The bear note opens, but in the background. Is there any way to have the note open in the foreground. None of the modifier key combinations work. thank you
Yes - hold the Shift key when you click the link.
Thank you. It was not working until I figured out that it’s Shift DOUBLE CLICK, not single.
thanks very much !
It’s a single-click here so you must have a different setting on your Mac, but you’re welcome anyways! :smiley:
