How to link inside db without submenue
Hi there,
I want to make a list of names inside my database in a rtf document and want to link these names to the folder/document where it belongs to.
I do this with the contextmenue, and the submenue. Okay.
Problem: Because the documents are deep in the hierarchy I often lost the path when I scolled through the submenues.
Is there any other way to link my names to the referring documents? I thought of copying the path (in the info panel) like an URL, but I found no way to do this.
Any help?
Thanks in advance.
You could also use Edit > Copy Item Link or Cmd-Option drag & drop.
okay, thanks.
