How to use AI function of DT4 Pro?
I am a paid user of chatGPT and perplexity, and of course, DT4 Pro.
Even though I added API Keys of the services, I got a reply from DT4 Pro "You exceeded your current quota, please check your plan and billing details. ~~ " when I input something in Chat.
Do I have to do something another to use the AI functions ?
That’s a reply from the provider. Which provider and model did you use? What exactly did you try to do and what was selected?
Just to double check:
The subscription to ChatGPT is not equal to the credit you use for making api calls to it.
That is, if you’re ChatGPT plus subscriber, you still need to put credit on your OpenAI account to make api calls.
Here is a link: https://platform.openai.com
Thank you all guys. I totally misunderstood. I registered chat gpt api and also installed ollama to my labtop. The AI function of DT4 pro now works correctly.
By the way, you should read Getting Started > AI Explained in the built-in Help and manual.
