Hello. I need help with tagging via chat.
I have a series of smart rules that search for PDF files by name and replicate the files to a specific group. When I use tagging via chat, it creates the tags, but it also creates groups (folders) with those files in the replicators folder. I have to manually delete these newly created groups with the replicated files.
There is no information on your smart rule, your AI model and prompt, and what the replicators folder is.
Thanks. The smart rule is very basic. It simply searches by filename and, upon meeting the criteria, replicates the files to a specific group. I’m using Gemini as my LLM and I’m not using any prompts; instead, I’m using the tag function via chat. The problem is that it adds the tags to the file but also creates groups (folders) in the replicator group.
Can you record a screencast showing the smart rule and the behavior you’re describing? You can hold the Option key and select Help > Report Bug in DEVONthink if you want to keep the information private
