Thanks. It’s still not working for me, but maybe I’m using the wrong version. Is there a place I can download the latest version? Should the script run as is without further hacks? Or do I need to copy my old keychain app over from my SL instal?
I hugely appreciate your help with this. Loving Pinboard and been a Devon fan for years. Excited about making the two work together.
Well . . . still no dice. I get an “Import Failed” message.
Should my Keychain Access.app be launching with it? It is, and I’m wondering if I screwed something up by picking it from a pop-up window when it first ran.
Thanks again for your help. In the apple script editor I can see that I’m getting a log like this:
display authentication dialog "Pinboard
https://api.pinboard.in/v1/posts/all"
--> {|password|:"xxxxx", user:"xxxxx"}
download markup from "https://api.pinboard.in/v1/posts/all" user "xxxxx" password "xxxxx" encoding "UTF-8"
display alert "DEVONthink Pro" message "Download failed." as warning
--> error number -1708
«event ascrgdut»
--> {button returned:"OK"}
tell application "Finder"
exists file "Macintosh HD:System:Library:Sounds:Glass.aiff"
--> true
do shell script "afplay /System/Library/Sounds/Glass.aiff"
--> error number -10004
tell current application
display dialog "Import has finished."
Result:
I’ve obviously removed the username and password, but I’ve checked them and they’re correct. I’ve also tested and can download my info manually from the site, so I’m not sure what else is happening.
Feel free to say “dunno, and I’m tired of helping you” and I won’t take offense.
Great that it works now. This looks like a bug in the script, but I don’t have a lot of time to fix it now. Fortunately long passwords with letters, numbers, and different case are also safe
Yep, and hopefully people having trouble with it will find this forum and discover that all they need to do is tweak their password a little and then they’re all set.
That said, if you have time, if you posted on your blog that you know about this issue, it’d probably decrease the number of knuckleheads like myself who bug you.
But again, thanks much for helping me figure this out. I’m a happy camper.
It took me very long, but I finally added the necessary information if you have a password with special characters. The solution should be to properly encode the username and password before using the API, but I don’t have enough time to add a fix.
The Keychain Scripting app got killed in OS X Lion. You have to either copy the older one over to Lion or download the Usable Keychain Scripting app, which should work, too.
Hi
I am trying to modify the script to include comments and creation date. Comments import just fine, but the creation date does not. I assume that DT can’t parse the date/time string exported by PB? time=“2012-02-26T17:24:39Z”
Here is the code snippet - any ideas welcome. TIA Joe
repeat with theElement in theElements
set theUrl to (value of XML attribute named “href” of theElement) as string
set theName to (value of XML attribute named “description” of theElement) as string
set theTag to (value of XML attribute named “tag” of theElement) as string
set theDate to (value of XML attribute named “time” of theElement) as string
set theComment to (value of XML attribute named “extended” of theElement) as string
set {od, AppleScript's text item delimiters} to {AppleScript's text item delimiters, " "}
set theTags to (text items of theTag)
on error
set theTags to {}
if not (exists record with URL theUrl) then create record with {name:theName, type:bookmark, URL:theUrl, tags:theTags, creation date:theDate, comment:theComment} in theGroup
I’m not sure whether this would be useful for anyone else, but having used the importer for a while, I have one request: It would be great to get the descriptions/notes on links with the import. I suppose the best place would be the Spotlight comments or some other kind of metadata. Would that be useful for anyone else? Would it be easily achieved?
Thanks to all!
Mark
UPDATE: Just saw on Page 2, directly above me, something attempting this very thing. Had any luck? Thanks!
Since Lion Apple decided to abandon Keychain Scripting altogether and you have either to use a version from Snow Leopard or an alternative in order to get the current script to work (see also red-sweater.com/blog/2035/us … g-for-lion).
I’m working on a much improved version of the importer, that is not only smarter, but gives you the option to choose between web archives and simple link entries. It doesn’t depend on Keychain Scripting, but uses the command line interface and parses its output. I’m testing it since weeks and there are no issues so far. I need to wrap everything up and release an update, but I don’t have the time right now and this probably won’t change in the upcoming months.
That said, the current version works, you just have to install a Keychain Scripting app.
you sir, are the biggest tease ever…
anyways. why not throw it up on github (or just here) for now with a minimal readme. some ppl might still be able to figure it out. better than waiting for months…
it works for me, its just importing bookmarks which are not useful…
It’s long ago and I haven’t tested compatibility with newer versions of DTPO. The version was basically finished and one scripting bug that affected the Pinboard script was (as far as I remember) fixed in some newer version of DTPO. The script still isn’t published and I’ve no time at the moment.
