I exported the html file from Raindrop to import. This is the format:
<DT><A HREF="https://" ADD_DATE="1639247418" LAST_MODIFIED="1639247467" TAGS="tag1" DATA-COVER="https://">Test</A>
Devonthink doesn’t recognize tags. Is there a way to fix it?
Did you use File > Import > Bookmarks from HTML file…? This doesn’t support such tags currently.
In this context, “TAGS” is just an arbitrary non-standard HTML element (and the HTML itself is kind of broken).
With a script. But some more context would be nice, like
@cgrunenberg Yes, I tried that feature: File > Import > Bookmarks from HTML file
@chrillek Yes, HTML is the only format available.
Then a script should scan for the tags and set them on the DT record. The relevant JavaScript code would look like that
const text = record.plainText();
const tagMatches = [...text.matchAll(/tags="([^"]*)"/gi)];
tagMatches.forEach(match => {
const tag = match[1];
// Add tag to list of tags for this record
I’ll try, thanks.
The next release will support tags in this case too.
