Sorry Bluefrog, but neither the original document nor his duplicate receives the stamp.
Thank you for support
Marc
No problem.
Can you post a screencap of the Imprint’s preview?
No problem.
Does this persist after quitting and relaunching DEVONthink or a machine reboot?
Yes it persists after both Mac and DT reboot
A fix for this working on El Capitan will be included in the next update to DEVONthink
When you took algebra 1 in high school, you plotted points like (2,3) meaning (x,y) where 2 is two units in the x direction (horizontal) and 3 is three units in the y (vertical) direction. You would simply plot that point (2,3).
The two-dimensional graph coordinate system you used is called the Cartesian plane. The coordinates you use are simply called “Cartesian coordinates”.
With Devonthink, the only difference is that the “origin” (0,0) is in the upper left corner of the PDF display.
Does that refresher help?
