Hi! I’m using DEVONthink in dark mode. I use the keyboard a lot instead of mouse clicking for speed when I’m filing inbox documents.
When I open the Move To… box and type out a partial folder name, the currently selected folder in the dropdown is light grey on gray. It is very difficult to see which folder is default highlighted before I hit the enter key.
Would be great if it would just use the blue background highlight so I can see where it is currently pointing. Thanks.
